Hello
I´ve received in recent time a new Cisco Pix 515e.
It´s home configured with an 192.168... Lan IP address but I wanted to configure it with a new one (172.16...) using the web interface provided by the machine.
The problem is that when I change it using the web interface, I can get a right ping (using 172.16...) but web access it´s totally unreacheable.
Because I can´t use the "save" command I restart the Pix 515e again and the old 192.168... address arise.
What do you thing I´m doing wrong?
Thanks you all in advance for your help
