port security help
Threaded View
Regarding TCP.IP ports. what ports should i disable and what ports
should i keep open on a cisco router within my network.
Re: port security help
On 31 Aug, 22:39, 93RX...@gmail.com wrote:
Nobody can tell you the answer to that question.  What would you want
to go in/out of your network?
i would start with
www
pop3
dns
smtp
any bespoke apps you have
not sure if you need
ntp
snmp
any routing protcols
I would block everything else and then begin permitting in/out as and
when people complain
they can't access various services.
Paul
www.howtonetwork.net
Site Timeline
