port forwarding port ranges and ipv6 tunneling
I'm currently setup using nat overloading on a 3620 and have a few ports
static forwarded which is working great. my question is how would the ip
nat syntax differ to forward a range of ports for say pasv ftp? could
someone provide some examples? I'm also trying to setup ipv6to4
tunnelling to hurricane electric and i've configured the tunnel with a
couple different setups. I can ping6 the internal /64 gateway but i'm
unaware why my router is unable to ping the ipv6 endpoint at he. Any
suggestions there would be welcome aswell. I've included a copy of my
current config below which is most likely a work in progress :)
Thanks in advance.
matterhorn#sh run
Building configuration...
Current configuration : 2948 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname matterhorn
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxx
memory-size iomem 15
clock timezone UTC -6
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name xxxxxxxxxxxxx.com
ip audit po max-events 100
ip ssh time-out 60
ipv6 unicast-routing
username user password 7 xxxxxxxxxxxxxxxxx
interface Loopback0
  ip address 192.168.9.1 255.255.255.0
interface Tunnel0
  no ip address
  no ip redirects
  ipv6 address 2001:470:1F01:xxxx::FDD/127
  tunnel source Ethernet0/0
  tunnel mode ipv6ip 6to4
interface Ethernet0/0
  description Outside interface to VLAN/DMZ
  ip address dhcp
  ip nat outside
  half-duplex
  no cdp enable
interface Ethernet0/1
  description Outside interface to VLAN/LAN
  ip address 192.168.0.xxx 255.255.255.0
  ip nat inside
  full-duplex
  ipv6 address 2001:470:1F01:xxxx::1/64
  ipv6 enable
interface Ethernet0/1.2
  encapsulation dot1Q 2
  shutdown
  no snmp trap link-status
  no cdp enable
interface Ethernet0/1.4
  encapsulation dot1Q 7
  shutdown
interface Serial1/0
  ip address 172.16.35.254 255.255.255.0
  clock rate 128000
interface Serial1/1
  no ip address
  clock rate 128000
interface Serial1/2
  ip address 192.168.42.3 255.255.255.0
  shutdown
  clock rate 128000
interface Serial1/3
  no ip address
  shutdown
router eigrp 100
  passive-interface Loopback0
  network 192.168.0.0
  auto-summary
ip nat inside source list 1 interface Ethernet0/0 overload
ip nat inside source static tcp 192.168.0.xxx 2160 interface Ethernet0/0
2160
ip nat inside source static tcp 192.168.0.xxx 22 interface Ethernet0/0 22
ip nat inside source static tcp 192.168.0.xxx 80 interface Ethernet0/0 80
no ip http server
no ip http secure-server
ip classless
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 60 permit 192.168.0.0 0.0.0.255
access-list 107 deny   ip 10.0.0.0 0.255.255.255 any log
access-list 107 deny   ip 172.0.0.0 0.255.255.255 any log
access-list 107 deny   ip 255.0.0.0 0.255.255.255 any log
access-list 107 deny   ip 224.0.0.0 0.255.255.255 any log
access-list 107 deny   tcp any any eq finger
access-list 107 deny   icmp any any echo log
access-list 107 permit ip any any
snmp-server engineID local 000000090200003080C52F80
snmp-server community snmp view cursociscodefault RO
snmp-server community xxxxxxx@es0 RW
snmp-server community xxxxxxxx RW 60
snmp-server contact hostmaster@xxxxxxxxxxx.com
snmp-server enable traps tty
dial-peer cor custom
line con 0
  login
line aux 0
  exec-timeout 60 0
  login
line vty 0 4
  access-class 1 in
  exec-timeout 0 0
  login
scheduler process-watchdog terminate
end
Site Timeline
