PIX 520 with 5.1(4) OS enable password recovery
Threaded View
I bought a PIX 520 @ ebay,  however, I could not do a password recovery
using a floppy as described @
http://www.cisco.com/warp/public/110/34.shtml
When I start the PIX with the floppy (which I created with rawrite.exe
and np51.bin):  I get the following message:
Finesse Bios V3.3
Booting Floppy
...................................Execing flop
Also, it does not takes the Esc or Ctrl + Break to get to the monitor
mode.
I have tried with CRT version 3.4.6 and WINXP Hyper Terminal with 9600,
8, none, 1 setting.
I have copied and pasted startup screen and sh verion for your
information:
Finesse Bios V3.3
Booting Floppy
Loading from Flash
128MB RAM
Flash=AT29C040A @ 0x300
BIOS Flash=AM28F256 @ 0xfffd8000
mcwa i82558 Ethernet at irq 11  MAC: 0090.2710.49cf
mcwa i82559 Ethernet at irq 10  MAC: 0090.27af.b59a
                         c i s c o S y s t e m s
                        Private Internet eXchange
                        Cisco Secure PIX Firewall
Cisco Secure PIX Firewall Version 5.1(4)
Licensed Features:
Failover:       Enabled
VPN-DES:        Enabled
VPN-3DES:       Enabled
Maximum Interfaces:     6
  ****************************** Warning
  Compliance with U.S. Export Laws and Regulations - Encryption.
                                          : (removed line to save
space)
FARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
Type help or '?' for a list of available commands.
Compiled on Mon 02-Oct-00 07:19 by morlee
Finesse Bios V3.3
emma up 19 mins 14 secs
Hardware:   SE440BX2, 128 MB RAM, CPU Pentium II 349 MHz
Flash AT29C040A @ 0x300, 2MB
BIOS Flash AM28F256 @ 0xfffd8000, 32KB
0: ethernet0: address is 0090.2710.49cf, irq 11
1: ethernet1: address is 0090.27af.b59a, irq 10
Licensed Features:
Failover:       Enabled
VPN-DES:        Enabled
VPN-3DES:       Enabled
Serial Number: 18020211 (0x112f773)
Activation Key: 0x4d467e42 0x2bb81f00 0xf2f39bfe 0x4b977554
Can anyone point me in the right direction please?
Thanks,
Suhi
Re: PIX 520 with 5.1(4) OS enable password recovery
Hi Suhi,
You may wish to investigate Appliances with a Floppy Drive:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a5d.shtml#withfloppy
Hope this helps.
Brad Reese
BradReese.Com - Cisco eBay Repair Service
http://www.bradreese.com/ebay-cisco-repair.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina  USA 28803
USA & Canada:  877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Cisco Power Supply Headquarters
http://www.bradreese.com/cisco-power-supply-inventory.htm
Thanks Brad,
I will try to follow the steps when I have the necessary files.
Unfortunately, I do not have access to CCO now.  Will have to wait
till....
Suhi
Hello All...
I am having the same exact problem...  the password recovery boot
floppy method isn't working fomr soem reason:
Finesse Bios V3.3
Booting Floppy
then it reboots on it own and does it again...
Also, it does not take the Esc or Ctrl + Break to get to the monitor
mode. I know the password floppy works as I was bale to use it on a
identical PIX 520...  does anyone have any ideas? Thanks,
xminer
Site Timeline
