I've just started the second half of my CCENT course, and we're just learning how to configure routers using the CLI.
Our homework problem is:
End devices-----Switch------(Fa 0/1) Router 1 (Fa 0/0) ---------- (Fa
0/1) Router 2 (Fa 0/0)--------Switch-----end devicesEach router has a switch and 3 end devices. The problem gives all the IP addresses and masks to configure.
From the end devices within Router 1's network, I can ping local devices, as well as Fa 0/1 (which is my gateway, right?) and Fa 0/0. I can't ping beyond that. Similarly, Router 2's network behaves the same way.
So basically the routers aren't seeing each other. I feel like I'm missing something very simple, but I can't figure out what.
I've quadruple checked all my addresses.
I could use a hint....thanks for reading this far.
