OSPF router id?
Hi there ,can anyone clarify how this is worked out please-here is my
take on things
The priority takes 1st priority! higher number wins
Then its the IP addy o fthe router(locally)so even if the higher IP is
on a different network(say S1 is 200.10.10.1 and e0 is 192.168.10.10)
S1 IP is the router ID-even if it is just applied to the 192 network?
This has confused me today-I did a practice exam for Sem3 and had an
OSPF question-I got it correct by using the Serial link IP address to
work out who was the DR-however on the quiz at the end of the chapter
for OSPF routing ,my tutor explained that the serial link is not
included......
In the question there were 3 routers -1,2,3
router 2 had the highest priority so it was DR
R1 had ip 192.168.1.3 and a Loopback of 7.1.1.1
R3 had ip eo 192.168.1.1 and a S1 of 200.20.20.1
I know R1 uses the loopback so its ID is 7.1.1.1 however if that wasnt
there would R3 still be the BDR because it has the S1 ip addy?
Thanks alot ,
Site Timeline
