Now with pictures!
Re: OSI Model Question
On Mon, 15 Sep 2008 18:40:51 -0500, "John Agosta"
Based on your remark, I figured this must have been a topic of
(possibly heated) discussion in the past. So I did a search for
"layer 1 header" on google groups for this newsgroup asuming that a
ton of stuff would come up. Not much did.
I did find that sonet has a header which identifies the contents of
the payload. So I guess this answers my question.
John Agosta wrote:
:) Hey John, long time!
Bob,
Others already chimed in, but the fact is, DOD's TCP/IP model won.
ISO's OSI model is dead dead dead dead. It's not even a useful
training aid since the four layers of TCP/IP is all that matters.
If one were being pedantic, one could argue that concepts like
manchester encoding mean that L1 header exists.
One could also argue that one is pedantic just by using the word
pedantic! :)
hsb
"Somehow I imagined this experience would be more rewarding" Calvin
Due to the volume of email that I receive, I may not be able to
reply to emails sent to my account. Please post a followup instead.
John Agosta wrote:
They're coming up the rack
And I ain't seen the sunshine since I don't know when
I'm stuck in the data centre and time keeps draggin' on
But those flames keeps a-burnin' on up to the backbone
When I was just a baby, my mama told me, man
Always be a good boy, don't ever play with LANs
But I patched a rack in Reno, just to watch it bridge
When I hear that aircon blowin', I clean my AUI.
Sorry, couldn't resist.
P.
Paul Matthews
paul@cattytown.me.uk
http://www.hepcats.co.uk
No, there is no such thing as a layer 1 header.
Data is encapsulated (which includes a header), as stated in CCNA material,
as follows:
- data
- segment
- packet
- frame
- bits
Framing is a layer 2 encapsulation and is dependant on the layer 2
technology. This can be tricky because some layer 2 and layer 1
technologies are closely bound, but not exclusive to one another.
Therefore, ethernet framing for transmission over copper cabling is the same
as ethernet framing over fiber optic cabling. This ethernet framing is
different than the layer 2 framing that token ring uses with copper cabling
and layer 2 framing that ATM uses over fiber optic cabling. The point is
that framing, which happens at layer 2, is not dependant on the layer 1
medium used.
It is understandble that framing may be considered dependant on the layer 1
technology because of the close relation of layer 2 data link and layer 1
physical technologies. T-1 lines, modem communication, and ethernet are
commonly related to copper cabling while FDDI and ATM are commonly related
to fiber optic cabling. With all of these relationships being thought of,
it is conceivable that one may consider framing to be dependant on the layer
1 physical technology when in fact it is not.
As I sometimes say, "Give me two copper wires and I can signal like a modem
for up to 56kb/s or like ISDN for up to 128kb/s. Give me two more copper
wires (for a total of 4) and now I can signal like a T-1 line, Ethernet,
FastEthernet, or GigabitEthernet at respective speeds of 1.5mb/s, 10mb/s,
100mb/s, or 1000mb/s. Replace my 4 copper wires with 2 fiber optic lines
and now I can signal like a T-3, Ethernet, FastEthernet, and
GigabitEthernet. Layer 2 data link technologies/protocols are all about HOW
you signal over the layer 1 physical medium."
Scott Perry
Indianapolis, IN
Scott,
Thank you for the excellent explanation. The key to this seems to be
signalling info which is contained in the header.
When you use frame relay to transport ethernet, are you encapsulating
a L2 protocol with another L2 protocol? I haven't seen that the OSI
model allows for that.
Bob
On Tue, 16 Sep 2008 12:45:42 -0400, "Scott Perry"
Frame-relay framing does not encapsulate or get encapsulated by ethernet
framing, they are replacements for each other.
Use the example from your question. Consider an ethernet LAN which crosses
a frame-relay WAN to get to an ethernet LAN on the other side.
* The originating host creates an IP packet destined for the receiving host
on the other end. The IP packet is encapsulated in an ethernet frame
destined for the next-hop router.
* The router receives the ethernet frame sent to it, removes the ethernet
framing, evaluates the IP packet to determine the detination, and
encapsulates the IP packet in a frame-relay frame destined for the next-hop
router.
* The next router receives the frame-relay frame sent to it, removes the
ethernet framing, evaluates the IP packet to determine the destination, and
encapsulated the IP pakcet in an ethernet frame destined for the receiving
host.
* The receiving host receives the ethernet frame sent to it, removes the
ethernet framing, finds that the IP packet is intended for itself, and then
retrieves the data from the original and unaltered IP packet.
Total: 3 data-link frames, 1 network packet
Scott Perry
Indianapolis, IN
On Wed, 17 Sep 2008 17:21:06 -0400, "Scott Perry"
actually - it can do. You describe routing IP over frame relay which
is not what was asked.
there is an encap defined for Ethernet over frame as well, which keeps
the Ethernet MAC frame.
Long ago i used it for LAT based terminal servers.......
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Stephen,
You may be correct but Scott answered my boneheaded question. I knew
(and forgot) that the router strips the incoming L2 header and
encapsulates with the outgoing frame type. But one sometimes needs to
be reminded of the basics again.
Bob
If stupidity even strikes educated people from time to time, what
would you expect from those who are not?
BS
it is worth remembering the OSI model is exactly that - a model
designed to make conversations about networking easier to understand
in a consistent way.
And a useful model usually involves abstrations to simplify the
discussions, or a way to ignore some detail that doesnt impact
whatever you do want to talk about.
Anyhow my take is that layer 1 can be more than just a lump of bits,
as that layer may need some structure to make it work.
Some plumbing needs clock info and other "layer 1" stuff when there is
no packet to maintain clock, sync and so on - think HDB3 on an E1 type
2 Mbps link for example, where the format maintains the clock
transitions.
Or maybe stuctured E1, where some 64k timeslots are used for a L2
frame and some are there for other reasons - maybe this example has 2
different "layer 2" aspects?
So, what is on the wire when there is no frame present? no layer 2
info as no layer 2 frame, so it cannot be "layer 2" ?
The reality is there are several ways in which OSI does not map
exactly into some real networks, and where there are in practice sub
layers, or the model layer boundaries do not match up exactly to an
implemention.
And all of those examples are not limited to the copper or fibre
transports suggested (ok - you can argue that T1 is defined to use
copper, but all the others have at least UTP & fibre varients).
Or 24 Mbps for ADSL 2+ (but not as far) :)
Um - 4 pairs for Gige on UTP?
And take the fibre away, use free space optics and these work without
any medium........
Regards
Bob Simon wrote:
This is a totally valid question. There is layer 1 framing (T1 ESF,
SONET, etc).
And with respect to some of these protocols, particularly ISDN, there is
even a layer3 in ISDN which indeed maps to layer 3 on the *OSI* model.
You are really transporting one protocol stack over another in this case.
Technically speaking, there is a layer1/2 in DSL, since most DSL uses
ATM encapsulation with VPI/VCI numbers.
Which may be confusing to some people who use PPPoE for their DSL links.
Its really PPP over Ethernet over ATM... so you have three layer 2
technologies there...
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Advice from all of you folks
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » KY: Magoffin County 911 offering new Text-To-911 service [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
