NM-1A-OC3MM and Cisco 2811
Hello,
I have a Cisco 2811 router. I bought a NM-1A-OC3MM ATM module and installed it in the router. The IOS version is 12.4(13a).
---------------------------------------------- show version Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version
12.4(13a) , RELEASE SOFTWARE (fc1) System image file is "flash:c2800nm-advipservicesk9-mz.124-13a.bin"
When I boot the router, I have the following message:
*Feb 2 17:39:55.067: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 154)) is not supported on this image. Please issue "show diag" in fully loaded IOS image to get the PA's information and verify if it is supported by this image, a newer version may be needed.
So I run the "show diag" command and I got:
---------------------------------------------- show diag Slot 1: Unknown (type 154) Port adapter Port adapter is disabled Port adapter insertion time unknown EEPROM contents at hardware discovery: Hardware revision 1.0 Board revision H0 Serial number 29378588 Part number 800-03700-02 FRU Part Number NM-1A-OC3MM= Test history 0x0 RMA number 00-00-00 EEPROM format version 1 EEPROM contents (hex): 0x00: 01 9A 01 00 01 C0 48 1C 50 0E 74 02 00 00 00 00 0x10: 88 00 00 00 02 10 10 17 FF FF FF FF FF FF FF FF 0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x30: FF FF FF FF FF FF FF FF FF FF FF FF
What is the problem???? Does Cisco 2811 do not support NM-1A-OC3MM?? Or I need a different version of the IOS?? If the problem is the IOS, what version will work find for me???
Thank you very much for your answer.
Eric Gamess
You probably need an adventerprise or advsp (service provider) ios if I'm not mistaken, ATM modules would most likely not be supported on IP services IOS.
Yandy Ramirez
Johann Lo
