I'm studying for the CCNP routing exam and want to get a firm understanding of NAT. I have a couple questions that a few of you might be able to answer better.
- What does the router look at first the routing table or the NAT table? And does it matter which way the traffic is coming into the router?
- I undertand what the Inside local/Global address and how they are used, but I'm uncertain of the Outside local/global address and why you would use them. Is the outside Global address a public (routable) address of a remote host? I.E Webserver in a remote network?? Not sure what the Outside local address. Can somone provide examples.
- When setting up Static Port Mapping:
router (config)# ip nat inside source static tcp 10.0.0.1 80
200.152.14.56 80I know this will setup any address trying to reach 200.152.14.56 on port 80 to be sent to 10.0.0.1. This is incoming, does anything happen when this local machine goes out to the internet? I'm not sure I tottaly understand this area.
- When setting up the intferfaces for NAT by applying the "inside" and "outside" to the interface, what does this essentially do?
Any help will be much appreciated, also any study material that you can guide me on this subject will help too.
Thanks
Matt
