Hi All, I have my 1605R router's outside on ether0 and inside on ether1. I have
my dsl modem connected in on outside (192.168.0.1 Modem - 192.168.0.2 Ether0). On the inside I have my 2908XL switch connected to Inside Ether1 which is dhcp the range 192.168.1.100 upwards.
On connect up, all is fine. I have 3 macs that get an IP from the given
range. However they dont get the DNS IP's sent to them, so I have had to manually type those in.
I can ping my modem on 192.168.0.1 from 192.168.1.103 with out any problems, but I cant get any internet on any of my macs.
Here is my conf !
cisco1605#sh running Building configuration...
Current configuration : 1098 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname cisco1605 ! enable secret 5 $1$l7iK$k2pWJZE0tCVCzTVlvYsDi1 enable password hello ! ip subnet-zero no ip domain-lookup no ip dhcp conflict logging ip dhcp excluded-address 192.168.1.0 192.168.1.101 ! ip dhcp pool home network 192.168.1.0 255.255.255.0 domain-name home.com dns-server 212.23.8.1 default-router 192.168.1.50 lease 7 ! ! ! ! interface Ethernet0 description connected to Internet ip address 192.168.0.2 255.255.255.0 ip nat outside ! interface Ethernet1 description connected to EthernetLAN ip address 192.168.1.50 255.255.255.0 ip nat inside ! interface Serial0 description connected to Router no ip address encapsulation ppp shutdown ! ip nat pool net192 192.168.1.100 192.168.1.254 netmask 255.255.255.0 ip nat inside source list 101 pool net192 overload ip classless ip http server ! access-list 101 permit ip 192.168.1.0 0.0.0.255 any ! line con 0 exec-timeout 0 0 password hello login line vty 0 4 password hello login ! end
