Now with pictures!
Subject
- Posted on
My Job on stake,Please help me
- 06-23-2007
June 23, 2007, 1:11 am
I'm v. new in CISCO world, our company open a office in Canada. They want me to
connect From New jersey to Montreal, What are step should I took to connect New
Jersey router to Montreal router. Any link any help is higly apprecaited, u can
save my job.
Please...............help me..........
Thanks
tomnj@usa.net
save my job.
Thanks
tomnj@usa.net
Re: My Job on stake,Please help me
to connect From New jersey to Montreal, What are step should I took to connect
New Jersey router to Montreal router. Any link any help is higly apprecaited, u
can save my job.
Hi there,
What type of routers are at both offies?
What are the comms lines?
Need information in order to help you.
Regards Andrew.
If those routers are connected to the internet directly, you can use GRE
tunnels. Just be aware that GRE tunnels are not encrypted. If your router
has an IOS image that supports IPSEC, you may want to apply IPSEC to that
GRE tunnel. I will provide an example of a simple GRE unencrypted tunnel:
Montreal
Say the internet IP assigned to the router is: 172.16.50.250
interface tunnel 0
ip address 10.0.0.1 255.255.255.252
tunnel source 172.16.50.250
tunnel destination 172.16.60.250
tunnel key 12345678
New Jersey
Say the internet IP assigned to the router is: 172.16.60.250
interface tunnel 0
ip address 10.0.0.2 255.255.255.252
tunnel source 172.16.60.250
tunnel destination 172.16.50.250
tunnel key 12345678
10.0.0.1 and 10.0.0.2 are the private IP addresses you are encapsulating
within the VPN tunnel (choose any address according to your own subnetting
scheme). After you enter that configuration, you should be able ping
10.0.0.2 from Montreal and vice-versa. This should give you your basic
router-router connectivity.
HTH
Montreal
interface tunnel 0
tunnel key 12345678
New Jersey
interface tunnel 0
tunnel key 12345678
HTH
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » The salient differneces between Link State and Distance Vector?
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » KY: Magoffin County 911 offering new Text-To-911 service [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
