Anyone have experience with setting up a Multilink Frame-Relay? I've been tasked with setting up a router (2610) with this type of config and ... I've never configured a Cisco outside of a lab enviroment.
They sent me a "sample config" that I can only guess is the configuration of the router on the otherside of the T1s.
If anyone can offer some help it would be greatly appreciated. I'm not even sure what to post here to help you help me, so just ask and I'll post it.
Brief steps for configuring Multilink FR should be the following:
1) configure interface mfr ( or subinterface if you need/want point-to-point ) ) as you would do with a serial
2) for each serial line you want to add to MFR bundle use encapsulation frame-relay mfr
Regards, Gabriele
"Matt" ha scritto nel messaggio news:eqdfso$a15$ snipped-for-privacy@news04.infoave.net...
That's where I'm having my problem. Everything I've read on Cisco's website says to do that, but I can't seem to create the virtual interface of "mfr". Seems like there is a step before this, or a requirment that I have not fulfilled.
The only things I can think of are OLD IOS or no more free IDB to create a virtual interface; you can check the latter ( 99% is not your case ) using "show idb"
Regards, Gabriele
"Matt" ha scritto nel messaggio news:eqf54p$c5$ snipped-for-privacy@news04.infoave.net...
Well, if you look up Multilink Frame-Relay, the two options (Multilink Frame Relay (FRF.16.1) Variable Bandwidth, and ..over L2TPv3AToM) do not list the
2610. But if you look up Frame Relay - Multilink (MLFR-FRF.16) the 2610 is actually listed.
