Hi
Can someone tell me if MPLS (multi protocol layer switching) and MLS (multi layer switching) are essentially the same thing?
Cheers
Hi
Cheers
Multi-Layer Switching (MLS) has become a highly desired method of accelerating routing performance through the use of dedicated Application Specific Integrated Circuits (ASICs). Traditional routing is done through a central CPU and software. MLS offloads a significant portion of routing (packet rewrite) to hardware, and thus has also been termed switching. MLS and Layer 3 switching are equivalent terms.
Multiprotocol Label Switching (MPLS) is a standards-approved technology for speeding up network traffic flow and making it easier to manage. MPLS involves setting up a specific path for a given sequence of packets, identified by a label put in each packet, thus saving the time needed for a router to look up the address to the next node to forward the packet to. MPLS is called multiprotocol because it works with the Internet Protocol (IP), Asynchronous Transport Mode (ATM), and frame relay network protocols. With reference to the standard model for a network (the Open Systems Interconnection, or OSI model), MPLS allows most packets to be forwarded at the layer 2 (switching) level rather than at the layer 3 (routing) level. In addition to moving traffic faster overall, MPLS makes it easy to manage a network for quality of service (QoS). For these reasons, the technique is expected to be readily adopted as networks begin to carry more and different mixtures of traffic.
AT&T has rolled-out MPLS Private Network Transport - PNT
Brad Reese BradReese.Com - Cisco Salary and Compensation Rates
Thanks Brad. In some statements I've read, MLS is defined as the explanation you've given for MPLS, i.e. treating packets from the same flow the same by labelling each packet and imitating what was done to the first packet. The first packet has to go through the router, but subsequent packets in the same flow bypass the router and are handled by the switch only.
In this definition for MLS, only IP is mentioned though. So would it be correct to say that MLS using different protocols, such as ATM or FR, is MPLS?
Cheers.
You may have MPLS confused with MLSP.
The three major components of MLS are:
To determine the best path is the primary function of routing protocols, and this can be a CPU-intensive process.
Thus, there is a significant performance increase with the offload of a portion of this function to switching hardware.
This performance increase is the goal of the MLS feature.
Two of the three major components of MLS are the MLS route processor (MLS-RP) and the MLS switching engine (MLS-SE).
The MLS-RP is the MLS-enabled router, which performs the traditional function of routing between subnets/VLANs.
The MLS-SE is a MLS-enabled switch, which normally requires a router to route between subnets/VLANs.
However, with special hardware and software, MLS-SE can handle the rewrite of the packet.
When a packet transverses a routed interface, the change (rewrite) of non-data portions of the packet occurs as the packet heads to the destination, hop by hop.
Confusion can arise here because a Layer 2 device appears to take on a Layer 3 task.
Actually, the switch only rewrites Layer 3 information and "switches" between subnets/VLANs.
The router is still responsible for standards-based route calculations and best-path determination.
You can avoid much of this confusion if you mentally keep the routing and switching functions separate, especially when they are within the same chassis (as with an internal MLS-RP).
Think of MLS as a much more advanced form of route cache, with a separation of the cache from the router on a switch.
MLS requires both the MLS-RP and the MLS-SE, along with respective hardware and software minimums.
The MLS-RP can be internal (installation in a switch chassis) or external (connection via a cable to a trunk port on the switch).
Examples of internal MLS-RPs are the Route Switch Module (RSM) and the Route Switch Feature Card (RSFC).
The third major component of MLS is the Multilayer Switching Protocol (MLSP).
You must understand the basics of MLSP to get at the heart of MLS and perform effective MLS troubleshoot procedures.
MLS-RP and MLS-SE use MLSP to communicate with one another.
Tasks include:
The enable of MLS.
Installation of MLS flows (cache information).
Update or deletion of flows.
Management and export of flow statistics.
MLSP also allows the MLS-SE to:
Learn the Layer 2 MAC addresses of the MLS-enabled router interfaces
Check the flowmask of the MLS-RP.
Confirm that the MLS-RP is operational.
The MLS-RP sends out multicast "hello" packets every 15 seconds with use of MLSP.
If the MLS-SE misses three of these intervals, the MLS-SE recognizes that the MLS-RP has failed or that connectivity to the MLS-RP is lost.
The MLS-SE checks for the cache MLS entry.
If the MLS cache entry and packet information match (a "hit"), the packet header rewrite occurs locally on the switch.
This rewrite is a shortcut or bypass of the router. The packet does not forward to the router as normally occurs. Packets that do not match are forwarded to the MLS-RP as candidate packets.
A local switch may occur for these packets. After the pass of the candidate packet through the MLS flowmask and the rewrite of the information in the packet header (without contact with the data portion), the router sends the packet toward the next hop along the destination path.
The packet is now an enabler packet. If the packet returns to the same MLS-SE from which the packet left, a MLS shortcut is created and placed into the MLS cache. Now, instead of the router software, the switch hardware locally rewrites that packet and all similar packets that follow (a "flow").
The same MLS-SE must see both the candidate and enabler packets for a particular flow for the creation of a MLS shortcut. (This requirement is why network topology is important to MLS.)
Remember, the purpose of MLS is to allow the communication path between two devices in different VLANs, with connection off the same switch, to bypass the router. This action enhances network performance.
With use of the flowmask, which is essentially an access list, the administrator can adjust the degree of similarity of these packets. The administrator can adjust the scope of these flows:
Destination address.
Destination and source addresses.
Destination, source, and Layer 4 information.
The first packet of a flow always passes through the router. From then on, the flow is locally switched. Each flow is unidirectional. Communication between PCs, for example, requires the setup and use of two shortcuts. The main purpose of MLSP is to set up, create, and maintain these shortcuts.
These three components (the MLS-RP, the MLS-SE, and MLSP) free up vital router resources through the allowance of other network components to take on some of the router functions. For certain topologies and configurations, MLS provides a simple and highly effective method to increase network performance in the LAN.
Sincerely,
Brad Reese BradReese.Com - Cisco Job Search
They are way different.
Basically MPLS is the addition of a label to a packet such that only the label need be read for a device to decide what to do with it. Initially this was to try to speed things up as just a tag needed to be checked when routers did stuff in CPU. The main advantage now is not performance as most ruters work in hardware but separation. Through the MPLS network it is the label that needs to be checked rather than the IP info.
That means an MPLS carrier could provide services to, say Microsoft and Cisco. they could both use the same area of RFC1918 network addressing and be able to function totally independantly.
MLS is Multi layer switching. The first packet in a flow will be processes in CPU, and then a cache entry written to the switch engine so that subsequent packets can be switched in hardware without having to trouble the CPU. This is where thing like code red cause problems to the network. At the router near the infected device traffic was being sent to random[1] addresses. These were not previously in the cache and needed full lookup. If you had a router with a large routing table *and* a default route the routing table was checked then the packet was forwarded according to the default so it could cause the same problem at the nest router. The real crippler was where a random address hit a valid subnet within the network, and the taget router had to ARP for lots of nonexistant addresses...
[1] I know it was not totlly random, but near enough...P.
If you add a label, it *IS* MPLS.
NO. That would still be MLS, it is only MPLS when a label gets attached and THAT is used for the forwardimng decision. Multi Protocol LABEL switching.
