made some progress
Threaded View
When I connect using the aux port I don't see the initial boot but get a
login (password) prompt.
When I connect using the console port, I get all the boot data and running
I can enter keystrokes in both scenarios, and it seems to accept the
keystrokes, but when I try to do a password recovery, it doesn't respond and
I can't get to rommon mode.
I tried all the possibilities for flow control and stop bits.  I also tried
NT old way to break boot.  Changed baud to 1200, held space key down for 15
seconds, and then reconnected at 9600.  It looks like the cable is OK since
it takes my attempts at passwords, etc.  so I don't know what else to try. I
always think there is some minor setting that needs to be changed to
Re: made some progress
I have just started password recovery on CCNA sem 2
Can u break the bootup cycle? On the router we are using(the royal we)
u use ALT + B to break.
o/r 0x2142
Hope this helps?
Mark Simmons wrote:
Site Timeline
