I have a bunch of 2950s to load configs, for which I already have the unique config files for. I put a procedure together which simply:
sets the tftp server to a 192.168.101.1 adx boot the router and say no to initial config dialog erase the startup config config vty with a password and login statements to allow tftp assign an ip adx to vlan 1 on the switch to 192.168.101.2 verify the tftp server can ping the switch copy the config to the startup config (copy tftp start) reload
The config is loaded after the switch is rebooted, but the vlans in the config file do not appear in the switch. It does however work when I do a copy run start after the copy tftp start
Why's this? I thought if you copy the config to the start-config it would be ok.
Any comments welcome.
Regards,
RB
