lightstream 1010 switch
Hi
if you had the opportunity to buy at a low cost ($100) a lightstream
1010 with 3 OC3 ATM ports, 1 switch route processor and 1 carrier module, would you get it for your CCIE lab?
My understanding is that it was phased out some time around 2000, too old?
TIA
/CM
Capitan Mutanda
Have you ATM interfaces for any of your routers? If you have ATM for at least two routers, it gives you the opportunity to do ATM. Otherwise, pass.
Paul Matthews
Paul Matthews ha scritto:
All I have is a 3640 with ATM-E1 4E1-IMA and a 1700 with G-SHDSL.
In a 5000 I've two WS-X5111 and in a 6500 one WS-X6324, but doubt that it would help for a minimal ATM network. By the way, my experience with ATM is only theoretical, no hands on
/CM
Capitan Mutanda
Capitan Mutanda ha scritto:
Looking around on ebay I found a 5000 ATM OC-3 LANE Module WS-X5158 that I could snug in my 5000 that has a RSM WS-X5302
tnx
/cm
Capitan Mutanda
Hi Capitan,
To view the "history" of "aged" Cisco Products you may find helpful:
Cisco Product Quick Reference Guides, CPQRGs
These aggregated guides go all the way back to 1999:
Sincerely,
Brad Reese BradReese.Com - Cisco eBay Repair Service
www.BradReese.Com
"Capitan Mutanda" skrev i en meddelelse news: snipped-for-privacy@k70g2000cwa.googlegroups.com...
Depends on the kind of CCIE lab you are settting up. If it is a CCIE R&S lab ATM is no longer needed. On the other hands are you going for the CCIE SP ATM and ISDN is still in there.
Best regards Martin Kiefer
Martin Kiefer
