LANs and ports
Threaded View
Are these sentences true:
Every port of a switch represents a separate LAN.
Every port of a router  represents a separate LAN.
Re: LANs and ports
lrantisi@gmail.com wrote:
The second statement is true. A router's job is to route packets between
separate networks whereas a switch is used to distribute frames around a
single network (ignoring VLANs etc).
Andrew Thompson
Re: LANs and ports
Do you think they are true?  Why? Why not?
BernieM
Re: LANs and ports
you really need to do your own homework
FWIW - these are really poorly written Qs......
it depends on what you mean by a "LAN" - if you mean a collision domain (a
single Ethernet) - then yes.
If you mean a layer 2 broadcast domain, then no for a layer 2 only switch,
maybe for a layer 3 switch depending on architecture
probably - but a real router usually can also bridge
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Re: LANs and ports
Quite. There are a number of good intro to networking books and web sites. The
OP would be well advised to go get a few and do some basic reading before
posting similar fundamental questions.
Paul Matthews                                         CCIE #4063
Please post questions to the NG, NOT by e-mail.
Re: LANs and ports
#1 is right, #2 is right if a bridging is enabled
Re: LANs and ports
switchports in the same vlan are not in seperate lans.
Site Timeline
