How do you disable keepalive on a serial port? I have tried several variations of the command but I am not successful. I am trying to accomplish this while in the interface configuration mode.
- posted
17 years ago
did you try?
int serial xxx no keep
Thanks, but "ntp" is the only option when using the show command once I have enter
ntp is the only option that begins with "n".
I am using the Boson simulator and I think it is a software problem.
"no" doesn't appear as a command using the "?" help but you can still use it a command prefix.
BernieM
