Hi all, I have done a couple of articles about ISDN configuration and would like to have you comments on them, are they complete? have I missed something? are they clear and easy to go through?
How to Configure BRI ISDN in a Cisco Router
Mohammed
Mohammed
Thanks for the tutorials. A couple of points, since you asked...
It isn't always clear which interface is being configured; Are you sure the information around PPP authentication is correct (and if it is, maybe it isn't clear) - isn't it the case that the password must be the same at both ends of the WAN link, and not necessarily the same as the enable secret password?
Thank you for taking the time to look at my articles. In older IOS version, there used to be a command 'ppp sent-username XXX password XXX'. Using this command, you were able to set the password and user name that your router will use to access the other end's router. But as far as CHAP is concerned, This is what Cisco says in defining the command "username": =============================== username
To specify the password to be used in the PPP Challenge Handshake Authentication Protocol (CHAP) caller identification and Password Authentication Protocol (PAP), use the username command. username name password secret name Host name, server name, user ID, or command name. password An encrypted password for this username. secret For CHAP authentication only; specifies the secret password for the local router or access server or the remote device. To prevent the secret from being stolen, it is encrypted when it is stored on the local router or access server. The secret can consist of any string of up to 11 printable ASCII characters. There is no limit to the number of username-password combinations that can be specified, allowing any number of remote devices to be authenticated. =============================== So, it is the secret password being used to authenticate in CAHP. Thank you for the note, I will adjust the article according to it.
Mohammed
I'm taking a CCNA course and was taught that the CHAP password was only encrypted if the command 'service password-encryption' was made, otherwise it was stored in the clear. The cisco reference you quote seems to suggest it is encrypted by default. Any idea why there is this contradiction? Version of IOS? The only refs I can find are ambiguous.
Thanks JP
If you are setting a CHAP password using the commands 'ppp chap hostname' and 'ppp chap password', you will need to encrypt it using the 'service password-encryption' command. However, if you don't set a specific CHAP password, the router will use its secret password and hostname as password and username for the PPP communications. And as you know, the secret password is by default encrypted.
Mohammed
Thanks, that is very clear.
But since I'm a bit dim, can I ask for one further clarification?
If on Router A I use 'username B_Hostname password B_Password' so that router B can be authenticated
If on router B I do not specify a password, the secret password is used.
So, on router A, unless I use 'service password-encryption', I will be storing router B's secret password in the clear? And even if encrypted, it is with the weak vignere cypher rather than the MD5 hash?
JP
This is true. This is way you SHOULD assign a different password. The usual scenario is that you are assigned a username and a password by an ISP for example. You will have to setup these username and assword pair as the ones you use in the PPP authentication.
Mohammed
Thanks very much for your responses.
the enable
Any time Jim
