I posted this in the cisco forums, thought it might be of use here also:
- write out the subnet mask bits (only in the octet in question if you want to save time)
- write out the bits for the network or host ID that is given for any problem, lined up directly underneath the subnet mask in bits.
- draw a line seperating host bits from network bits.
eg. 12.25.87.69/19
255.255.111|00000.00000000 012.025.010|10111.01000101from the above example, be able to answer the 4 following questions: what is the network ID what is the broadcast IP how many hosts can this network support what is the host range
get proficient at that, and any subnetting question should be cake.
When I did the TCP/IP exam for NT4.0 (using the sybex book written by Lammle), the IP addressing chapter was filled with these questions. Since then, I have never had to re-study IP addressing for any subsequent test, including CCNA (twice. yes, i let my ccnp/ccdp expire, so i had to start from scratch again).
- for testing purposes, if you are the least bit unsure, WRITE IT OUT.
- write out the powers of 2 BEFORE you start the exam on your scratch paper they give so time is not taken off of the exam
