IP subnetting
Threaded View
Can someone please explain how the answer to this question is
obtained ?
How many subnets are gained by subnetting 172.17.32.0/20 into multiple/
28 subnets?
They answer is 256, but I can not figure out how to come up with that
answer.
Thanks for the help
Re: IP subnetting
RIckH wrote:
If you keep 172.17.32.0/20 as is, you have just one big network (of course).
If you use a /28 mask, then you have the following subnets (relative to the
original address and mask):
172.17.32.0/28      .00100000.0000 0000  (last two octets, space at /28)
172.17.32.16/28     .00100000.0001 0000
172.17.32.32/28     .00100000.0010 0000
172.17.32.48/28     .00100000.0011 0000
172.17.32.240/28    .00100000.1111 0000  (16 subnets so far)
then:
172.17.33.0/28      .00100001.0000 0000
172.17.33.240/28    .00100001.1111 0000  (other 16 subnets )
and so on until
172.17.47.0/28      .00101111.0000 0000
172.17.47.240/28    .00101111.1111 0000
So, you have 16*16 subnets (eg, 256) if you use a /28 mask.
You can also see this very quickly if you think that you gain 8 bits for the
subnet part (/20 -> /28), thus you have 2^8 = 256 subnets.
Ok, strictly speaking, you "gain" 255 subnets (you had one, and now you have
256), but I hope you got the idea.
Re: IP subnetting
Thanks, That makes perfect sense now.
Re: IP subnetting
then:
and so on until
Re: IP subnetting
2^(28-20) = 256 subnets (with ip subnet-zero)
172.17.32.0/20        172.17.32.0-172.17.47.255
172.17.32.0       (16 subnets)
                                172.17.32.0-172.17.32.15
                                172.17.32.16-172.17.32.31
                                172.17.32.240-172.17.32.255
172.17.33.0     (16 subnets)
                                172.17.33.0-172.17.33.15
                                172.17.33.16-172.17.33.31
                                172.17.33.240-172.17.33.255
172.17.47.0    (16 subnets)
                                172.17.47.0-172.17.47.15
                                172.17.47.16-172.17.47.31
                                172.17.47.240-172.17.47.255
Regards,
Gabriele
Re: IP subnetting
I found a site that does a really good job at explaining this  (In My humble
oppinion)
Site:  http://www.firewall.cx /
the actuall explanation: http://www.firewall.cx/ip-subnetting-intro.php
Cheers,
the_Druid
Site Timeline
