try enabling 'ip subnet zero' It should be on by default since v12.0
I am not familiar with the Boson Simulator but do I assume that the default commands that are enabled on an actual 2501 are on in the simulator such as 'ip routing' etc..? Since this is a simulator have you just for the sake of identifying whether this is a limitation of the simulator (which I doubt but never know). reconfigure the with classful addressing.. say 192.168.1.x 255.255.255.0 and 192.168.2.x
255.255.255.0 on the other. Let me know how you make out.Hello
I use boson 5.0 simulator, 2501 router:
Press Enter to Start
Router# Router#enable Router#config Configuring from terminal, memory, or network [terminal]? Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#hostname Rmain Rmain(config)#interface Serial 0 Rmain(config-if)#ip address 223.0.0.2 255.255.255.252 Rmain(config-if)#no shutdown %LINK-3-UPDOWN: Interface Serial0, changed state to up Rmain(config-if)#exit Rmain(config)#interface Serial 1 Rmain(config-if)#ip address 223.0.0.129 255.255.255.252
223.0.0.0 overlaps with Serial0Why ??
Thanx Michal
i tried, but still the same problem. Here is my config:
Rmain#show ru Building configuration...
! Version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Rmain ! ! ! ip subnet-zero ! ! ! ! interface Serial0 ip address 223.0.0.2 255.255.255.252 no ip directed-broadcast ! interface Serial1 no ip address no ip directed-broadcast clock rate 125000 ! interface Ethernet0 no ip address no ip directed-broadcast shutdown ! interface Bri0 no ip address no ip directed-broadcast shutdown ! ! ip classless no ip http server ! ! line con 0 transport input none line aux 0 line vty 0 4 ! no scheduler allocate end
Where is the problem ?
Thanx Michal
