Now with pictures!
Subject
- Posted on
IOS upgrade problem
- 01-12-2007
January 12, 2007, 1:44 pm
I recently upgraded the IOS on my 2950, the files are zipped up in a .tar
file because it includes HTML stuff.
Because there is only 8mb flash on the switch I had to delete the old file
first then copy the new one down via tftp server, it was all going well till
I reset the switch, it did not extract the files but just copied it as the
.tar file.
Then I could do nothing with it except delete it, copy a .bin file down via
xmodem (which took nearly an hour) then start again.
This time I did it using Cisco Network Assistant and it worked fine, I
deleted the old file, copied the .tar file and Network Assistant extracted
all the files properly.
My question is obvious, why did it not extract the files when using tftp?
did I miss a command off or something?
Thanks in advance
.tar file.
Thanks in advance
Re: IOS upgrade problem
Check this for the correct upgrade precedure:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml#concept10
Posted via a free Usenet account from http://www.teranews.com
Yeah this is the line of code I should have used:
2950#archive tar /xtract tftp://20.20.20.2/c2950-i6q4l2-tar.121-13.EA1.tar
flash:
Thanks Drake
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » 2950 setup issues
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
