hung ip addresses?
Threaded View
Guys,
 At work we are seeing more laptops have a hung ip address when the user
goes home from work, (it retains the ip address from work). Due to security
constraints, they cannot do a release/renew because they lack admin rights.
Does anyone have any suggestions on this?
Thanks,
RF
Re: hung ip addresses?
It's most likely the same security restraints that prevent them from
releasing/renewing their IP manually is also preventing it from working
automatically.
Might want to consider using domain-specific security measures instead.
Guys,
Thanks,
RF
Tell the I.T. Support
To set the DHCP SERVER up so that it releases the IP address as laptop
disconnects from there network
security
rights.
Is there even a possibility to send this with the DHCP-lease?
I would ask the IT-department to set a lower timeout on the ip-adresses
so that the copmuter would try to get a new dhcp-lease every 5 minutes
or so. (or you could shutdown the laptop during travel home (and then it
would ask for a new ip once you start it up again).
DHCP Server
Under Scope Options
Click on Advanced
Vendor Class Change DHCP Standard Options to Microsoft Options
Select 002 Microsoft Release DHCP Lease on Shutdown
This will release the DHCP address
Hope this is of Help
Fred
This helps if you use Microsofts DHCP-server, not the one I currently
use... But I'll look for info about this on my DHCP-server-software.
create a log off script
with the runas Administrator(local)  acount
to release ip address
Create a OU for laptops - create a GPO
you can use the  loopback in the GPO to Merge with laptop Computers
it
user
Perhaps try something with the lease time?
HOW TO DO IT !
DHCP Server
Under Scope Options
Click on Advanced
Fred
user
Site Timeline
