Now with pictures!
Subject
- Posted on
- Joseph Keegan
September 18, 2007, 3:46 am
In the outside-in access-list (acl_out), make sure that the following
entries are present:
access-list acl_out permit icmp any any time-exceeded
access-list acl_out permit icmp any any unreachable
access-list acl_out permit icmp any any echo
access-list acl_out permit icmp any any echo-reply
I've seen the question asked hundreds of times, and since I finally
found how to do it without allowing ALL icmp, I thought I'd share.
Hope it helps!
-J Keegan
j keegan at ctny dot net
Hope it helps!
-J Keegan
Re: How to enable TRACEROUTE through a Cisco PIX, ASA
Not quite. By opening any any echo you have now made your network pingable
from the real world. By adding unreachable you have now given the outside
world the ability you see what addresses you are using. There are only 2
things needed for trace, thats the time-exceeded and echo-reply. I would
recomend that you remove the other 2 for obvious security reasons.
If I want to allow ping, would below be acceptable?
access-list 111 deny icmp any any fragments
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any source-quench
access-list 111 permit icmp any any time-exceeded
If that is inbound on your outside interface, you are now wide open on ICMP,
well not WIDE open, but close enough. The ONLY thing you need for you to be
able to ping out is icmp echo-reply. If you want to trace out you need
echo-reply and time-exceeded. Anything more and it's potentially a higher
security risk than needed.
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Hot Jobs - HCL - Noida/Chennai/Gurgaon/Mumbai
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
