How to add LOCAL login option after tacacs+ for pix
Threaded View
I would like a pix to first look to a tacacs server to login, then use the
local database if the tacacs server is not available.  I can find the
commands to do either, but not both.  For instance with a tacacs server
mytacacs:
aaa authentication serial console mytacacs
or for local
aaa authentication serial console LOCAL
To get what I want can I use a single combo command like a router or will
two commands work, ie
aaa authentication serial console mytacacs LOCAL
or
as separate statements?  I have no easy lab pix to play with and the command
reference statements online show only one or the other.
BW
Re: How to add LOCAL login option after tacacs+ for pix
On Mon, 27 Nov 2006 16:17:28 +0000, BW wrote:
you have to use a single statement like you have:
make sure yo'ure running the latest version of pix os, whether its 6.3(5),
or a 7.x OS.
Site Timeline
