How i'm return my 2950 switch to basic default configuration???
tx
Nir
tx
Nir
Cat2950# write erase Erasing the nvram filesystem will remove all files! Continue? [confirm]y[OK] Erase of nvram: complete Cat2950# Cat2950# reload
System configuration has been modified. Save? [yes/no]: n
!--- Do not save the configuration at this prompt. Otherwise, the switch !--- reloads with the current running configuration and does not reset to default.
Proceed with reload? [confirm]y
2w0d: %SYS-5-RELOAD: Reload requested
Although if you get a CCNA question about this Cisco recommends that you don't do this but reconfigure the device.
thanks a lot
You cant reconfigure some settings... read your ccna book again
Write erase gets rid of config but also ensure the vlan.dat file held on flash is also deleted as otherwise vlans will still show
sh vlan - to see if vlans exist Dir flash - to view flash storage delete flash:vlan.dat - to delete vlan.dat sh vlan - verfiy all vlans gone
