HELPME: Prefered Routing using Dialer Watch.
Threaded View
Hi All,
Have you ever tried to implement dialer watch? Yes, I know this is not
the best way to implement dial backup which most people will use
floating route. However, for the sake of curiosity, I want to try to
create a small scenario where two routers are connected using Frame
Relay (FR) link and a dial backup whenever particular route is gone from
the routing table.
However, I can get the BRI0 disconnected and while primary link is
already up.
I've put the details about this scenario on
http://www.davidsudjiman.info/?p=156
Appreciate your help.
thx
David Sudjiman
Re: HELPME: Prefered Routing using Dialer Watch.
You've got "stuff" going accross the link thus not allowing the idle timeout
to happen. Do a log on the acl and find out what it is. Right off the bat,
it could be CDP, should should disable that on the bri's.
I finaly got it working. If you keen, just visit the link
http://www.davidsudjiman.info/?p=156 as I put 2 solutions for it.
It was not about the "stuff" but thanks anyway for your reply. I
appreciate it!
thx
David Sudjiman
Site Timeline
