can anyone point me in the right direction, this is my config:
Router#show running-config Building configuration...
Current configuration : 1001 bytes ! version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! no logging buffered no logging buffered logging rate-limit console 10 except errors enable secret 5 xxxx enable password xxxx ! memory-size iomem 20 ip subnet-zero no ip routing no ip finger ip name-server 62.31.176.39 ip name-server 62.249.250.90 ip name-server 194.117.134.19 ! ! ! ! interface Ethernet0 ip address 192.168.2.1 255.255.255.0 ip nat inside no ip route-cache half-duplex ! interface FastEthernet0 ip address dhcp ip nat outside no ip route-cache speed auto full-duplex ! interface Serial0 no ip address no ip route-cache shutdown ! ip nat inside source list 102 interface FastEthernet0 overload ip classless no ip http server ! access-list 102 permit ip 192.168.2.0 0.0.0.255 any ! line con 0 transport input none line aux 0 line vty 0 4 password xxxx login ! end
from here the router I can ping anywhere, from the PC I can ping the LAN and WAN side of the router but nothing beyond it
can anyone help?
