how would i implement an access control list on a cisco router?
lets say i have a mini network setup, with 8 computers and 4 routers. and each 2 set computer is attached to a switch. (so it will look like a star network)
how would i;
stop a telnet from a workstation to a router, stop a ping from a workstation to a workstation.
For telnet filtering you can place an ACL on the line itself. Note the ACL is created normally but the placement command is "access-class" Creating the ACL: Router(config)#access-list 2 permit Router(config)#access-list 2 deny any Placing the ACL: Router(config)#line vty 0 4 Router(config-line)#login Router(config-line)#password $#@!~ Router(config-line)#access-class 2 in
You need to use an extended or named ACL to filter icmp/ping. Note- you do not use an operator ("eq") with ICMP, and the service is "echo" not "ping". Creating the ACL: Router(config)#access-list 112 deny icmp echo Router(config)#access-list 112 permit tcp any any
Placing the ACL - note "access-group" is used for interfaces. Router(config)#int fa0/0 Router(config)#access-group 112 in
Firstly, as Aubrey said, you need to specify "host" or wildcard mask
0.0.0.0 for the first command. Secondly, you need to permit all other IP traffic instead of TCP traffic. Otherwise, non-TCP packets such as UDP packets will also be blocked.
First for each IP address you need to specify "host" or wildcard mask
0.0.0.0 or some other mask to cover a group of addresses.
Secondly, yes effectively, if .4.2 and .5.2 are on different subnets and/or VLANS and are connected to different gateways/routers; and provided you also set up an ACL to filter traffic in the other direction.
I know it's technical, but it is a technical topic, did you check out the link in my other post? ACLs are at the top edge of "Basic Routing" (and used to be in "Intermediate Routing") as a level of difficulty - an understanding of IP routing will help make sense of it all.
However, preventing ping between 2 workstations on the same subnet/VLAN would require some host Operating System TCP/IP fiddling.
