Heat and Fans in Home Lab environment
Threaded View
As all you know, it is very "noisy" to manage  a home lab.
Actually on my 2600 & 2950 I don't hesitate to remove the fan connector
(just unplugged the connector on the motherboard)
Furthermore I let them open, so they can "breath".
Is it risky? I hesite to do the same things with a 3640.
What is your opinion?
Thx in advance.
Re: Heat and Fans in Home Lab environment
If you've removed the case and they can breathe there should be no risk (
unless they are at 100% LOAD 24/7, but since you've an home LAN it's not the
case ).
This is only an opinion of mine.
Regards,
Gabriele
Thanks Gabriele
Heat, noise and electricity is a real problem with a home lab! I don't
know what to sugggest. Below is my LAB. I just installed a larger AC
duct to make the systems more usable in the space. Send me some
pictures of your home lab.
PW=howard
http://imageevent.com/hhuntley/computerlab
Wow, it is amazing !
I'll try to take some pictures with a real camera.
Sven
I changed the fan in my 2611 to one from Quietpc.com (the
three-conductor-connector it comes with fits easily onto the two pins that
come out of the motherboard).  It makes less noise than the PC now.
Dik
Thanks for the tips.
Site Timeline
