See my question at
- posted
17 years ago
See my question at
Instead of: frame-relay map 192.168.11.2 30 broadcast
shouldn't it be : frame-relay map 192.168.11.2 42 broadcast ??
================================ >See my question at
Nope cause arn't DLCI only local so u dont care what the DLCI is on the remote side
the map statment is to map a layer 3 address to a layer 2 address, so u put the remote router (r1) ip address not 192.168.11.2 (R3)
Basic ur telling the router to get to this layer 3 address go out via this layer 2 address.
Correct.
Yup.
Look VERY carefully at the IP addresses configured. I'll put a few blank lines so you may be in with a chance to see if that is enough for you to work it out yourself.
A few more.
A few more.
Right I'll just put the relevant command in. What I put here may not be enough for the interface to work correctly.
int s0/0 ip address 192.168.11.2 255.255.255.0 fram map ip 192.168.11.2 30 br
The two addresses are the same. *either* we have the wrong address configured on our interface, or more likely the remote end should be 192.168.11.1 in the map statement - we have mapped our own IP address to the DLCI.
Assuming we only have the two routers, and R1 should be .1 what we may want in the real world is:
R1: int s0/0 ip address 192.168.11.2 255.255.255.0 fram map ip 192.168.11.2 42 br fram map ip 192.168.11.1 42 br
R3: int s0/0 ip address 192.168.11.2 255.255.255.0 fram map ip 192.168.11.2 30 br fram map ip 192.168.11.1 30 br
What that should then do is allow us to ping our own interface as well.
Paul.
