FR and DTE/DCE clock-rate
Going thru a few labs for the BSCI exam...
I have a 2521 acting as the FR switch and attaching all various router models (2610-21, 2501-14-25). (Below is the 2521 config.)
Question: Does the clock rate need to be set on the FR switch in order for this to work? When I try to set the clock on the 2521 s0-1 it gives: %Error: This command applies only to DCE interfaces. I do not however have the same problem with s2-3 (. Must 'dce-terminal-timing-enable'?)
What do I need to know about these cross-over cables I am using? Does it matter what end is plugged into which interface type (Sync/Async)?
Just a bit confused...
Chris Rondthaler TV Guide Inc.
----------------------------------------------------------------------- IOS Ver.=12.2 ---------------------------------------------------------------------- C2521#sh run Building configuration...
Current configuration : 2037 bytes ! version 12.2 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption service udp-small-servers service tcp-small-servers ! hostname C2521 ! logging rate-limit console 10 except errors enable secret 5 $1$NHF3$jkYkvvIlqoMhye2mW84Bs. ! ip subnet-zero no ip finger ! no ip dhcp-client network-discovery frame-relay switching ! ! ! ! interface Serial0 description CONNECTION TO LOS_ANGELES no ip address encapsulation frame-relay no ip route-cache no ip mroute-cache frame-relay intf-type dce frame-relay route 21 interface Serial1 20 frame-relay route 22 interface Serial2 20 frame-relay route 23 interface Serial3 20 ! interface Serial1 description CONNECTION TO LONDON no ip address encapsulation frame-relay no ip route-cache no ip mroute-cache frame-relay intf-type dce frame-relay route 20 interface Serial0 21 frame-relay route 22 interface Serial2 21 frame-relay route 23 interface Serial3 21 ! interface Serial2 description CONNECTION TO PARIS no ip address encapsulation frame-relay no ip route-cache no ip mroute-cache frame-relay intf-type dce frame-relay route 20 interface Serial0 22 frame-relay route 21 interface Serial1 22 frame-relay route 23 interface Serial3 22 ! interface Serial3 description CONNECTION TO NEW_YORK no ip address encapsulation frame-relay no ip route-cache no ip mroute-cache frame-relay intf-type dce frame-relay route 20 interface Serial0 23 frame-relay route 21 interface Serial1 23 frame-relay route 22 interface Serial2 23 ! interface TokenRing0 no ip address no ip route-cache no ip mroute-cache shutdown ! interface BRI0 no ip address no ip route-cache no ip mroute-cache shutdown isdn x25 static-tei 0 cdapi buffers regular 0 cdapi buffers raw 0 cdapi buffers large 0 ! ip kerberos source-interface any ip classless ip route 0.0.0.0 0.0.0.0 192.168.3.1 no ip http server ! ! ! line con 0 transport input none line aux 0 transport input all line vty 0 4 no login ! end
C2521#
Chris Rondthaler
