What would you find in an EIGRP routing table if route summarization is configured on the routers Serial0 interface, and it summarizes routes learned from its Ethernet0 interface?
A. A summary route pointing to the Serial0 interface.
B. A summary route pointing to the Ethernet0 interface.
A is the answer. It summarizes on the interface that it is advertising, not learning. It will learn the routes on E0 and summarize those routes out S0, with the route being back to interface S0.
Correct Answer is C (A summary route pointing to the Null0 interface) Thanks to Owen Roth
"In EIGRP, the router doing the summarization will build a route to null0 (line 18) for the summarized address. Let's check Shannon's routing table:
Shannon#sh ip route 172.20.0.0 .... 172.20.0.0/16 is subnetted, 6 subnets C 172.20.100.0/24 is directly connected, Ethernet0 C 172.20.101.0/24 is directly connected, Ethernet1 D 172.20.0.0/16 is a summary, 00:12:11, Null0 C 172.20.102.0/24 is directly connected, Ethernet2"
