I all, my provider wrong to take me correct DLCI value for the configuration router, is there a way to capture DLCI value from a router console for a correct configuration??? thanks in advice Enzo
- posted
18 years ago
#show frame-relay pvc
the output will show the DLCI as unused
it is also posible that you have set the wrong LMI type
change it to cisco, q933 or ansi , clear the interface and try show frame-relay pvc again to query comand to set the lmi-type is: (config-if)#frame-relay lmi-type ?
you can see if the router exchanges LMI status with the ISP-switch using: #show frame-relay lmi the output should contain Status querys send: Status recvd:
good luck man ======================================================= NEW on the Internet: cisco irc chat groep irc://irc.intersecting.net/cisco.certification =======================================================
