Hi Guys I have a read alot about the differnces between a bridge and a switch and now I am getting confused. Please help Thanx Shaun
- posted
18 years ago
In function they are both the same; in implementation a bridge functions at a software level, where the switch functions at a hardware level (i.e. a bridge runs some software to gain it's function, but a switch's function is in hardware (using ASIC's)).
The end result is that a switch is many times faster at forwarding frames than a bridge.
BL
In article , Buzz Lightbeer writes
Would it also be true to say that in general terms:
a bridge has few ports (maybe two) a switch has multiple ports (maybe 16 upwards)
a multiport bridge, yes.
i agree w/ everything said so far, but would like to add: a bridge is also capable of connecting two different media types, for example, token ring and ethernet, or wireless and ethernet etc etc. not that a switch can't do this, but even when a switch implemements this, it's a bridging function and not a switching function.
Thanx for all the replies. really appreciate it Shaun
No, you could (past tense used as no-one really buys bridges these days), get 16+ port bridges.
BL
switch is really a marketting term that came later, which this thread defined well. On a cisco exam, pretend to take the term seriously.
