Now with pictures!
Subject
- Posted on
DHCP + static IP on the same network?
- 05-18-2008
May 18, 2008, 6:26 am
Can somebody please tell me if I can use DHCP and static IP-networking
on the same network? My problem is that connecting one machine using
static IP with wifi is failing due to nerworking-tool issues. The rest
of the machines work fine on static IP, including a Mac on wifi. So, if
I can use DHCP and static at the same time it would solve a problem for me.
Thanks for an answer.
Re: DHCP + static IP on the same network?
Yes, you have to configure DHCP server to do not use some
ip addres, then, on servers or devices which need static IP
address you have to disable DHCP client and configure this
IP static addresses on them in the usual way.
I.E. if your DHCP server is on a CISCO router, you must
type:
R1(config)# ip dhcp excluded-address 192.168.1.1 192.168.1.18
then configure DHCP server in the usual way to use IP
addresses from 192.168.1.0/24 network.
On nie, 18 maj 2008 o 06:26 GMT, Huub wrote:
Hi, of course you can... just specify on dhcp server excluded addresses
which you want to assign manually and dhcp won't try to use them.
If you run DHCP on Cisco IOS use following command:
Router(config)# ip dhcp excluded-address low-address [high-address]
pozdr. Slawomir Kawala
JID: slwkk [at] alternatywa [dot] net
GSM: (0)601-398-348
GSM: (0)601-398-348
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Need CCNA Lab Equipment in Edmonton, AB
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » checking for a heartbeat
- — The site's Newest Thread. Posted in » Wireless Networking
