Quite often after you have completed your work on the computer, you will try to delete useless folders and files to free up the space on your system but you are unable to do so. Whilst deleting these data you may have encounter error message such as cannot delete file, corrupted file or path is too long. These annoying errors can be resolved effectively with long path tool. Windows tool to delete or copy folders and files with filename too long or path too long error. All you have to is browse for the file and then press the button to delete or copy it. This application resolves the problem with the inability to delete and copy folders and files with long paths in Internet explorer. These might be created by adware, virus, Mac OS and other software. Ordinarily, one cannot access these kinds of files in Windows and as a result cannot delete or copy them either. Cleanup files. This application supports easy removal of undesirable files and folders. It is able to delete files with path which contains well over
260 characters in addition to files with dots in the name or trailing spaces. The utility will not require any installation and can launch directly from the setup. These are some of the other error messages that you could encounter while using Windows: Cannot delete file - Access denied The destination or source file might be in use There's been a sharing violation The file is being used by another user or program Cannot delete folder or file. The file name specified is too long or not valid. Error Deleting folder or file- posted
12 years ago
- Delete/Copy Path Too Long Files
