interface BRI0 description connected to ntt 81019998887654 ip address 10.12.15.5 255.255.255.0 encapsulation ppp dialer idle-timeout 30 dialer load-threshold 40 either dialer map ip 10.12.15.8 name TestKingB 81019998888901 dialer map ip 10.12.15.9 name TestKingC 81019998881234 dialer map ip 10.12.15.4 name TestKingD 81019998881122 dialer-group 1 ppp authentication pap ppp multilink
What's true about the type of dial-on demand routing being implemented? A. By configuring legacy DDR on interface BRI0, calls made to all three sites will use the same communication parameters. B. Calls made using BRI0 will attempt to use the authentication configured for the dial rotary, and if unsuccessful, will use pap authentication. C. By configuring BRI0 as a member of a dial-group 1, communications parameters assigned to the group will override those configured on the interface. D. The dialer profile communication parameters will override those configured directly on interface BRI0.
Any ideas?
