Can I cross connect a pair of 1602s using the CSU/DSU port? Like you can serial ports with the right cable?
If so anyone have the cable layout to do that?
thanks
thanks
On any 56k CSU's you can use a Cisco rollover cable to cross connect them.
For 56k yes the rollover works fine it crosses over the relevent pairs. For any other type of connection (T1, Ethernet etc) you would need to appropriate crossover cable.
