connectivity question - CCNA
dear greater cisco intellect,
i've been doin' some practice exams, and am havin' problems understanding the answer to one of them:
A user on your network indicated that he/she cannot reach a remote site. Following info: is given:
local PC 10.0.4.36/24 default gateway 10.0.4.1 remote server 10.0.6.251/24
from the remote site, the following was done:
ping 127.0.0.1 - unsuccessful ping 10.0.4.36 - unsuccessful ping 10.0.4.1 - unsuccessful ping 10.0.6.251 - unsuccessful
so the what's the problem?
well the answer says that tcp/ip in not installed. and that's the reason. but i'm thinkin' it's because the remote physical layer is at fault. i mean if you try to ping the nic card (127.0.0.1) and are unsuccessful...wouldn't that mean the the nic card is not workin'. and therefore, we have a physical layer problem?
just wonderin' if i could get some insight on this one.
regards,
mgodinez seattle, wa
partly cloudy...
michael.godinez
You know that the NIC is installed, because it has an IP address --
10.0.6.251/24
If troubleshooting, and you get no response when Pinging 127.0.0.1, there is a problem with TCP/IP services. 127.0.0.1 is a loopback address and should never go down. The solution would be to reinstall or reinitialize the TCP/IP stack.
It could be possible that the NIC was unintstalled or unseated. There are a number of reasons why the TCP/IP services could stop working, one of which is a bad NIC, but that goes beyond the scope of the question. BTW, there are other network services protocols besides TCP/IP... you could have a IPX/SPX or AppleTalk, or CLNS without TCP/IP. The physical layer could be working fine with another protocol and still not work with TCP/IP.
bkvalentine
bkvalent,
thank you so so much for the response. i see the err of my ways now.
good stuff!!!
regards,
cloudy...
michael.godinez
127.0.0.1 is logical, doesn't touch the NIC
q_q_anonymous
Cisco wants you to test connectivity doing the following four steps:
Ping local loopback address (127.0.0.1) : If failes the TCP/IP stack is a problem. Ping your own local PC address : If failes the NIC is bad or no cable connected to it. Ping your default gateway : If failes the local router is a problem. Ping remote host : If failes you have a "remote" problem.
Dude
