Now with pictures!
- andre rodier
April 1, 2008, 8:19 am
Good morning everybody,
After successfully configuring NAT on a cisco ASA5510, I have a problem
with the ASDM access.
I have created an ssl certificate request, and successfully imported the
X509 certificate in the Cisco.
I also had set up a subdomain that points to the external IP address of
the Cisco, for instance admin.red2.co.uk.
For privacy reasons, I have changed the subdomain name, which is not
admin.
Yesterday, I have successfully acceded the asdm, using http server
enable, and adding my IP address.
But now, whe I try to access to the cisco asdm using https secure
connection, and port 443, I have the error :
"admin.red2.co.uk interrupted the connection."
I had try to debug the connection using the command "debug http 255", but
the only message I receive from the console is :
red2asa1(config)# listen: Received HTTP request.
Started http listen on interface ext port 443
Nothing more.
Some other informations may be useful :
red2asa1(config)# show crypto ca certificates
CA Certificate
Status: Available
Certificate Serial Number: 04e4da
Certificate Usage: General Purpose
Public Key Type: RSA (1024 bits)
Issuer Name:
ea=support@cacert.org
cn=CA Cert Signing Authority
ou=http://www.cacert.org
o=Root CA
Subject Name:
cn=admin.red2.co.uk
PrincipalName: admin.red2.co.uk
OCSP AIA:
URL: http://ocsp.cacert.org /
Validity Date:
start date: 15:57:55 GMT Mar 29 2008
end date: 15:57:55 GMT Sep 25 2008
Associated Trustpoints: cacert
red2asa1(config)# show crypto ca trustpoints
Trustpoint cacert:
Subject Name:
cn=admin.red2.co.uk
Certificate configured.
red2asa1(config)# show running-config asdm
asdm image disk0:/asdm-523.bin
asdm history enable
Any idea ?
admin.
Nothing more.
CA Certificate
Status: Available
Issuer Name:
o=Root CA
Subject Name:
cn=admin.red2.co.uk
OCSP AIA:
Validity Date:
Trustpoint cacert:
Subject Name:
cn=admin.red2.co.uk
asdm history enable
Any idea ?
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » used cisco routers and switches
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » TN: Smyrna receives report on bombing impact [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
