Hi
I did the cit exam today and it was a killer, the simulators really eat into your time. I have a few questions about the simulators.
1) one simulator was a router which was been configured via telnet when the connection died. You've been advised that the line and protocol are still up. You can access the routers on either side of the middle(problem) router and have to fix a routing problem. But you can't use the Configure or debug commands.!!Any ideas what to do with this.?? I tried to telnet onto the problem router but this wasn't allowed either.
Also there were loads of command outputs from eigrp & igrp issues. Could anyone advise where i could get samples of such outputs where the problems are explained.! (i.e Stuck in Active)
Thanks,
Alan
