Using TeraTerm or Hyperterminal with VT100. I am not able to use ESC key or Ctrl-Break to break the boot process to go into password recovery mode. Does anyone have this problem or solution to this?
thanks,
|| || |||| |||| ..:||||||:..:||||||:.. c i s c o S y s t e m s Private Internet eXchange ----------------------------------------------------------------------- Cisco Secure PIX Firewall
Cisco Secure PIX Firewall Version 5.1(4)
Licensed Features: Failover: Enabled VPN-DES: Enabled VPN-3DES: Disabled Maximum Interfaces: 6
****************************** Warning ******************************* Compliance with U.S. Export Laws and Regulations - Encryption.This product performs encryption and is regulated for export by the U.S. Government.
This product is not authorized for use by persons located outside the United States and Canada that do not have prior approval from Cisco Systems, Inc. or the U.S. Government.
This product may not be exported outside the U.S. and Canada either by physical or electronic means without PRIOR approval of Cisco Systems, Inc. or the U.S. Government.
