Now with pictures!
Subject
- Posted on
Cisco Aironet 1100 configuration
- 04-24-2007
Re: Cisco Aironet 1100 configuration
Clients control which access point they connect to via the received signal
strentgh. There are a couple protocols that can be used with the lightweight
AP's that will help but with a standalone it is up to the client. Also, if
you have more tha 15 clients connected to any one access point you can
expect severe performance degredation. You can often set your clients to
prefer a certain AP via its MAC address. This can greatly help you balance
the load. If that is not available you will have to play with the output
power settings on the dot11radio interface.
Sometimes you can also set your clients to only talk on one channel. If so
you can put the three AP's on channel's 1,6 and 11 and divide your
workstations up accordingly.
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » CCNA links updated at: http://tech.groups.yahoo.com/group/ccna-exams pass on...
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
