Now with pictures!
Subject
- Posted on
cisco 831 and my miserable upload speeds
- 01-08-2007
January 8, 2007, 6:51 am
i replaced my BEFSR41 with an Cisco 831. my upload speeds since then
have dropped significantly. i was able to get close to the 384kbps with
the linksys router, but now i get a lousy range of 50-112kbps.
i'm pretty sure this has something to do with my QoS policies, but i'm
not sure where the problem lies.
my understanding was these QoS policies set a fixed bandwidth in the
event specified traffic needed bandwidth. if there is no need for the
bandwidth then any traffic can use the bandwidth. at the moment it
seems that the block of bandwidth is isolated and no other traffic can
use it.
here's my current config:
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname pluto
boot-start-marker
boot-end-marker
enable secret 5 xxx
aaa new-model
aaa session-id common
resource policy
ip subnet-zero
ip nbar port-map sip udp 5060 5061 5062 5063 5064 5065
no ip dhcp use vrf connected
ip cef
ip domain name sol.home
no ip ips deny-action ips-interface
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
class-map match-any warcraft
description warcraft
match access-group name warcraft
class-map match-any VoIP
match protocol rtp audio
class-map match-any normal_traffic
match protocol http
match protocol secure-http
match protocol dns
match protocol smtp
match protocol pop3
match protocol ntp
match protocol icmp
class-map match-any sip
match protocol sip
policy-map MyQoSPolicy
class VoIP
set dscp ef
priority 90
class warcraft
priority 10
class normal_traffic
priority 20
class sip
priority 15
set dscp ef
class class-default
fair-queue
no crypto isakmp ccm
interface Ethernet0
ip address 10.10.100.1 255.255.255.248
ip nat inside
no ip virtual-reassembly
interface Ethernet1
bandwidth 384
ip address dhcp
ip nbar protocol-discovery
ip nat outside
duplex auto
service-policy output MyQoSPolicy
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list OUTBOUND_ADDRESSES interface Ethernet1
overload
ip nat inside source static tcp 10.10.100.5 6112 interface Ethernet1
6112
ip nat inside source static udp 10.10.100.5 6112 interface Ethernet1
6112
ip access-list standard OUTBOUND_ADDRESSES
permit 10.10.100.4
permit 10.10.100.5
permit 10.10.100.2
permit 10.10.100.3
ip access-list extended warcraft
permit udp any any eq 6112
permit tcp any any eq 6112
control-plane
banner motd ^CC
You are connected to $(hostname) on a private network.
Use of this system may be logged or monitored without further notice.
Unauthorized access is prohibited.
Violators will be prosecuted.
^C
line con 0
no modem enable
line aux 0
line vty 0 4
transport input ssh
scheduler max-task-time 5000
end
use it.
version 12.3
no service pad
hostname pluto
boot-start-marker
boot-end-marker
enable secret 5 xxx
aaa new-model
resource policy
ip subnet-zero
ip cef
ip ssh time-out 60
match protocol http
match protocol dns
match protocol smtp
match protocol pop3
match protocol ntp
match protocol icmp
match protocol sip
class VoIP
set dscp ef
priority 90
class warcraft
priority 10
priority 20
class sip
priority 15
set dscp ef
class class-default
fair-queue
interface Ethernet0
ip nat inside
interface Ethernet1
bandwidth 384
ip address dhcp
ip nat outside
duplex auto
interface Ethernet2
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
ip classless
ip http server
overload
6112
6112
permit 10.10.100.4
permit 10.10.100.5
permit 10.10.100.2
permit 10.10.100.3
control-plane
banner motd ^CC
^C
line con 0
no modem enable
line aux 0
line vty 0 4
transport input ssh
end
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Cisco CCNA Lab
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
