Cisco 7609 optical gigabit interface - strange problem
Hi all, I have a strange problem with the optical gigabit interface of a Cisco switch 7609. This is the problem: I have two 7609 cisco switch (A and B) cross connect with a optical fiber. All port of both switches are configured as followed:
switchport switchport mode acces shutdown no cdp enable no ip address end
I have connect two ports of the switches and I brough up the interface. I got the following result if i tun 'show ip interface brief ' on the switches:
SW A - SW B port 1 - port 1 --> link down protocol down port 2 - port 1 --> link up protocol up port 1 - port 2 --> link up protocol up port 2 - port 2 --> link up protocol up
Have anyone some idea for the possible cause of the problem?
Thank you
BR \\Sergio
sergio.lorusso
Uzytkownik "sergio.lorusso" napisal w wiadomosci news: snipped-for-privacy@j72g2000cwa.googlegroups.com...
I don't exactly understand your description.... port2 - port1, what does it mean ? you connect port 2 on switch A to port 1 on switch B ??
Beside this missunderstanding, i think that it's a stp...
Stavros
Hi Stavros I have connected with the same optical fiber cable and the same GBic these pair of port on the switches. For each pair of port i got that result.
BR \\Sergio
Stavros ha scritto:
sergio.lorusso
