Cisco 2600 routing problem
I am trying to create LAB/TEST env I want to separate my 172.7.8.0 network with this new 10.190.1.0 network It is not working need some help Venkat
This is the Configuration I have for the internal router
Ver 12.1 no service pads ! ! hostname Internal ! ! enable secret enable password
IP subnet-zero Interface FastEthernet0/0 IP Address 172.17.8.70 255.255.255.0 no IP redirects no IP Mroute-cache duplex auto speed auto
Interface serial0/0 no IP Address Interface FastEthernet0/1 Ip Address 10.190.1.2 255.255.255.0 no IP redirects no IP Mroute-cache
duplex auto
speed auto
no CDP enable
router IGRP 1 redistribute connected Network 10.0.0.0 Network 172.17.0.0
IP classless no IP http server
end.
This router is for creating a 10.190.1.0 network internally
The connection sequence is From SW4006( which is on 172.17 network) to this routers fastethernet0/0 giving IP address 172.17.8.70 ( e0 of the router is
172.17.8.70)
From fastethernet0/1 of this router I connected a unmanaged SW IP
address for this interface is 10.190.1.2 From this unmanaged SW I connected My LapTOP giving IP addess 10.190.1.5 and GW
10.190.1.2 Now From the Router I can Ping/traceroute to any 172.17.8.X Ip addresses I can ping and traceroute only 10.190.1.2 which is this router's fastethernet0/1 IP address I am not able to ping my Laptop which has an IP 10.190.1.5.
From 172.17.8.X network I can only ping this router's e0 IP which is
172.17.8.70 ( and rest of 172.17.8.x network) but I can not ping any 10.190.1.x network
When I do tracert from my laptop(10.190.1.5) to any 172.17.8.X network I get this
1ms 1ms 1ms 10.190.1.2 then * * * * request timedout.
VENKAT
Humm that is strange.
I just setup this on my lab at home and it works.
I didn't copy and paste....I just used what you gave me
Version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! ! ip subnet-zero ! ! ! interface Serial0 no ip address no ip directed-broadcast
backup interface shutdown ! interface FastEthernet0/0 ip address 172.17.8.70 255.255.255.0 no ip directed-broadcast backup interface no fair-queue ! interface FastEthernet0/1 ip address 10.190.1.2 255.255.255.0 no ip directed-broadcast backup interface no fair-queue ! ! router igrp 1 network 10.0.0.0 network 172.17.0.0 ! ip classless no ip http server ! ! ! line con 0 transport input none line aux 0 line vty 0 4 ! no scheduler allocate end
very strange..Maybe try a fresh config
Min
It will help if you post the output from the following commands issued on the router in question --
show ip route show ip protocols show running
Cisco da Gama
ciscodagama
thanks for the reply
I ran the setup again and configured the e0 and e1 interfaces with
172.17.8.70 and 10.190.1.2 respectively still not working Am I doing anything wrong Need Help to solve this problem
Thanks Venkat
VENKAT
Thanks
Sh running is already there ( begining of this email)
Show ip Protocols from router says:: routing protocol IGRP 1 network
10.0.0.0 172.17.0.0
Internet Protocol routing is enabled Fast Ethernet0/0 is up Line protocol is up internet address 172.17.8.70/24 Serial0/0 is down Line protocol is down Fast Ethernet0/1 is Line protocol is up internet address 10.190.1.2/24 show ip route is... codes.. c.. .... Gateway of last resort is not set
172.17.0.0/24 is subnetted 1 subnets 172.17.8.0 is directly connected to Fastethernet0/0 10.0.0.0/24 is subnetted 1, subnets 10.190.1.0 is directly connected to Fastethernet0/1
thanks
Venkat
VENKAT
Did you find out what was wrong?
You have enabled Ip routing?
Silly question but I have to ask :)
Min
