Cisco 2513
Threaded View
I just purchased a Cisco 2513 to prepare for the ccna exam is it possible to
use this router with my cable modem.
Re: Cisco 2513
networknic wrote:
Depending on the IOS you're running you just need to set the eth
interface that terminates your cable modem to get its IP address via
DHCP. Something like this:
interface FastEthernet0/1
  ip address dhcp
You'll also need to set up NAT and your default route to your provider.
With an ACL set up for NAT and port forwarding should you need it
requires a little more research but is something you should learn to do.
Site Timeline
