Thanks all. I was able to get to the Cisco 2505. However this is the boot strap:
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 14336 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 11.1 may not be correctly under
stood. F3: 3832048+95972+196092 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) 3000 Software (IGS-I-L), Version 11.1(24), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 04-Jan-99 19:00 by richv
Image text-base: 0x030206C0, data-base: 0x00001000
cisco 2505 (68030) processor (revision K) with 143
Processor board ID 07043624, with hardware revision 00000000
Bridging software. X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
8 Ethernet/IEEE 802.3 repeater ports.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
%LINK-3-UPDOWN: Interface Ethernet0, changed state to up %LINK-3-UPDOWN: Interface Serial0, changed state to down %LINK-3-UPDOWN: Interface Serial1, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down %LINK-5-CHANGED: Interface Serial1, changed state to administratively down %SYS-5-CONFIG_I: Configured from memory by console %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) 3000 Software (IGS-I-L), Version 11.1(24), RELEASE SOFTWARE (fc1) Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Mon 04-Jan-99 19:00 by richv
Here are my questions:
How do I get to the loging screen? What do I need to do to upgrade the firmware to OS 12? Do you guys have any other recomendations before I start playing with this pupy?
Thank you,
Praxi
